procedure
I can not debugger this program Experiment4.pxp (87.91 KB)
HJDrescher
function programmation ()
string f
Make $f
wave  w= f
variable a,b,c,x
	a=1
	b=2
	c=-1
	f[x]=a*(x*x)+b*x+c
	for (x=5;x<10;x+=1)
		print x, f[x]
Several issues:
* Use indentation for structuring, the code is easier to read and to debug.
f
is an empty string. This cannot be converted to a wave reference (the "
* Again
Make /O
* Please read the manual about wave indexing carefully. You will discover that
x
is a very bad choice for a variable name, especially for an index
f
is a string (foot note: characters can be accessed via
, hence no compiling error here -- but that is not what you want to do!) the wave is called
w
* the assignment should be in the loop here --- BUT: please read the manual about wave indexing (yes mentioned twice): you will end up with something like
w=a*p^2+b*p+c
outside your loop again at this point
* please read the chapter about wave scaling. Now you probably want to write
w=a*x^2+b*x+c
, as well outside the loop
Please note the color of x and p versus of a, b, and c in the tagged text above!
Please run
displayhelptopic "The Waveform Model of Data"
displayhelptopic "The XY Model of Data"
displayhelptopic "Changing Dimension and Data Scaling"
displayhelptopic "Waveform Arithmetic and Assignment"
from the command line ( ctrl-j ) one by one.
HJ
