Igor reloads my experiment several times when I open Igor
When I start Igor, it loads (and reloads) my experiment several times about 5 or 7 times before I can use it.
I tried to reinstall the software but nothing has changed.
I also installed the 6.1 version and the problem does not appear (but some packages I use in my .pxp are missing). Then when I update to 6.37 the problem comes back.
Any idea would be appreciated :)
Thank you!
Did you try to save the experiment in a new file? Is the behavior also present in the new file?
Can you reproduce this effect with a small demo experiment file you might share?
I guess one of the packages is causing trouble. Start with a minimal experiment and subsequently add your packages and see when the error comes back.
HJ
February 8, 2017 at 02:49 am - Permalink
If it is Mac OS, try going into the General system preferences and checking the Close Windows When Quitting App checkbox.
February 8, 2017 at 07:10 am - Permalink
I am running Mac OS 10.10.5 (Yosemite) and Igor Pro 6.37.
It happens when I LAUNCH Igor by opening a .pxp file. It also does it when I start Igor from the App menu (for instance when clicking on the Igor icon in the Dock) but certainly because I set my OS so that any app loads the last document ("experiment" in Igor) opened if it were not close prior to quit the app (I don't remember how I set this up on my Mac though).
Please find attached a sample .pxp file that does the trouble when I open Igor with it. Sometimes it does, sometimes it does not restart. I is weird. Right now it did not restart, but 5 minutes ago it did. I restarted Igor a couple times in the meantime...
Thank you for your help and attention,
Tijead
February 9, 2017 at 09:03 am - Permalink
What Howard was referring to is the Mac OS trying too hard to be helpful. When you close an application it will try to determine what windows were open; it expects each window to be a separate document. But Igor doesn't work that way, and the OS interferes with Igor properly opening an experiment file. So the problem shows up when you re-open Igor, but the problem is caused by information the OS has saved when you last closed Igor.
February 9, 2017 at 09:12 am - Permalink
that's a real shame because it makes me change this setup for my whole OS but indeed it solved my problem.
Thank you all.
Tijead
PS : does this setting also has to be checked when using the new Igor 7?
February 9, 2017 at 09:23 am - Permalink
