sjr51 sjr51 IIRC you can use XLLoadWave/J=1 to get a list of the sheet names in the string S_value then load each one individually. Here is an example cut from a larger procedure file. // This function will load the tracking data from an Excel Workbook /// @param pref prefix for excel workbook e.g. "ctrl_" Function LoadMigration(pref) String pref String sheet, prefix, wList Variable i XLLoadWave/J=1 Variable moviemax = ItemsInList(S_value) NewPath/O/Q path1, S_path for(i = 0; i < moviemax; i += 1) sheet = StringFromList(i,S_Value) prefix = pref + num2str(i) XLLoadWave/S=sheet/R=(A1,H1000)/O/K=0/N=$prefix/P=path1 S_fileName wList = wavelist(prefix + "*",";","") // make matrices Concatenate/O/KILL wList, $prefix endfor Print "***\r Condition", pref, "was loaded from", S_path,"\r ***" End Log in or register to post comments February 14, 2017 at 11:01 pm - Permalink
