Data Browser: optional echoing of Custom Commands
ModifyBrowser, Igor echoes the generated intermediate command to the command history. This can be annoying if one tries to use the DataBrowser as an input device (see this forum contribution). A possible solution is to add a choice to put this echo On/Off via the "Preferences" button in the DataBrowser.
When you set up your interface execute the command:
ModifyBrowser echoCommands=0
This should eliminate the printing in the history when you use "Execute Cmd...".
January 4, 2010 at 09:33 am - Permalink
I fed your answer back to the original forum topic.
Wolfgang Harneit
January 4, 2010 at 11:39 am - Permalink
