x2pnt vs FindValue
I'm a bit confused with the usage of
x2pnt and its relationship with FindValue.In the past I have been able to use
x2pnt to delimit a region of a wave to be fitted by an equation and all worked good.Today, when attempting to use
x2pnt again in another procedure I still cannot understand the output I was getting.For example, for a random wave with n number of points, every time I tried to print
x2pnt(wavename, xvalue), instead of printing out the point/position of the xvalue on the wave, I just got xvalue itself. I ended up going for FindValues which worked fine.What am I missing here? Is there any limitation in the use of x2pnt that I am not considering? the documentation seems quite trivial about it.
What is the difference between the two functions in terms of usage?
Thanks in advance.
R.
PS: Incidentally,
pnt2x was also printing the point number rather than the xvalue.
March 17, 2017 at 08:48 am - Permalink
what does
say?
HJ
March 17, 2017 at 08:50 am - Permalink
March 17, 2017 at 10:58 am - Permalink
Many thanks to the input guys!!
Cheers,
R.
March 17, 2017 at 02:09 pm - Permalink
Could you share the basic concept of your solution to others with a similar issue?
HJ
March 17, 2017 at 05:53 pm - Permalink
Cheers,
R.
March 18, 2017 at 06:53 am - Permalink
Also, the guided tour section "Waves - The Key Igor Concept" covers much of the same material. If you have not done the guided tour, choose Help->Getting Started. It is essential for understanding Igor.
March 18, 2017 at 10:23 am - Permalink
