    Naming of Columns
A column with label "Hold", if it exists, specifies held coefficients. A 1 in this column indicates that the corresponding entry in column zero should not vary during the fit.
It looks like I could view the table (via edit), change column name via a procedure. What is the recommended practice?
DisplayHelpTopic "Dimension Labels"March 28, 2017 at 10:34 am - Permalink
March 28, 2017 at 12:51 pm - Permalink
