appending same data to right axis
I am trying to append same data to left and right axis.
but error occures with wave name which I cannot solve.
My wave names are -0.5 V etc, so it should be typed as '-0,5 V'.
it works with commend windows but not with procedures.
It would be grateful if experts give some valuable comment on that.
Function plotfordisplay()
		//add logscale on right axis
		wave VG
		String traces=TraceNameList("",";",3)
		variable i
			for (i=0; i
I think you need
TraceNameToWaveRef
to reference your waves.
Here is an example, where I have modified your function, and made some example data so as to have a self contained snippet that illustrates the point (this is always a good idea!).
		wave VG
		variable i
			for (i=0; i<itemsinlist(traces); i+=1)
				String trace = Stringfromlist(i, traces)
				wave appendaa = TraceNameToWaveRef("", trace)
				appendtograph/R appendaa vs VG
		ModifyGraph log(right)=1
Function doStuff()
	// make some fake data
	Make/O/D/N=20 VG = x
	Make/O/D/N=20  '-0,5 V' = gnoise(0.1) + exp(x/10)
	Make/O/D/N=20 '-1,0 V' = gnoise(0.1) + (x/10)^2
	Make/O/D/N=20 '-1,5 V' = gnoise(0.1) + 1.5
	// Make initial graph
	Display '-0,5 V'  vs VG
	AppendToGraph '-1,0 V' vs VG
	AppendToGraph '-1,5 V' vs VG
	// call the function
	plotfordisplay()
Hope this helps,
Kurt
You might also want to have a look on "liberals names". The "-0" is causing trouble with various commands but automatic quotes might help...
displayhelptopic "Programming with Liberal Names"
displayhelptopic "PossiblyQuoteName"
HJ
It perfectly works for me.
I appreciate your help!
KurtB wrote: I think you need
TraceNameToWaveRef
		wave VG
		variable i
Function doStuff()
	plotfordisplay()
Hope this helps,
Kurt
