What would be the correct syntax for extracting a string from a string list and then assign that string to a name of a wave?
I can never get the compile to pass, sigh...
Thank you thomas and A.G., I don't have Igor7 installed yet. I downloaded demo and see what the function is. Is there a way to see "inside" of functions contained in Igor?
mwpro wrote: What would be the correct syntax for extracting a string from a string list and then assign that string to a name of a wave?
It's not clear from your question whether your string list is a list of names of already existing waves or is a list of names to be used when creating new waves. Consequently, there are two possible solutions.
March 24, 2017 at 11:23 am - Permalink
March 24, 2017 at 02:36 pm - Permalink
March 30, 2017 at 03:12 pm - Permalink
For both cases use to get a list item. I suggest you look up the StringFromList function in command help to get a better understanding of the syntax.
Then, for the first case, get a reference to the wave with .
For the second case, create the wave and get a reference to it with something like the following:
Here's a snippet to demonstrate how the second case could be used:
This example is fine for version 6.xx of Igor.
Hope this helps.
March 31, 2017 at 05:44 am - Permalink
March 31, 2017 at 02:05 pm - Permalink
