short cuts to toggle between procedures
I know Ctrl+Alt+M can cycle through the open procedure windows
However, it is not an efficient way to locate a procedure when the number of procedure is big (considering 100 procedures)
More often, we just need toggle between two procedures: the current procedure and the previous procedure (like alt-tab in Windows)
Is there a quick way to realize this?
thanks
aclight
In IP7, you can keep the Windows->Procedure Windows->Procedure Browser dialog open and double click on the procedures listed there to bring the window forward. Not quite the same thing you are asking about, but it's a little closer than just Alt-Tabbing through them all.
hrodstein
You can toggle between any two windows by first bringing them to the front and then,
On Windows, press Ctrl-E (Send to back) and Shift-Ctrl-E (Bring to front).
On Macintosh, press Cmd-tilde (Send to back) and Shift-Cmd-tilde (Bring to front). Tilde is ~. I'm not sure how you do this on a non-English keyboard.
wings
hrodstein wrote: You can toggle between any two windows by first bringing them to the front and then,
this works!
thanks!
wings
Thanks for your help.
I have another question. People in our lab complain about the too small looking of the controls on a panel in Igor6.
Of course, they are using igor 6 under win10 with a high-resolution display.
We know Igor7 works fine on high-resolution displays. But we now need igor6 because we have a great lots of procedures which run fine under igor6 but not so good under igor7(I am trying to find the reason, but before that ,Igor 6 is prefered).
From igor7's helptopic about high-resolution display, I know the too small looking is because controls command uses pixels, instead of points.
Is there an easy way to make the control command draw controls in points under igor 6?
or any other solution can make the controls look normal?
Thanks
xufriedman
Do you mean controls in Panels are too small? If so, I deal with this by increasing the font size of every control to 12, and setting the font to Verdana, which is intrinsically huge. I also routinely use magnification of Procedure and History windows at 125-150% on my Mac. It helps these tired old eyes.
-Matthew
wings
xufriedman wrote: Do you mean controls in Panels are too small? If so, I deal with this by increasing the font size of every control to 12, and setting the font to Verdana, which is intrinsically huge. I also routinely use magnification of Procedure and History windows at 125-150% on my Mac. It helps these tired old eyes.
-Matthew
Yes.
If number of controls is small, I can make it looks bigger by just dragging each control to a proper size, as you say.
However, there are about twenty panels, each of them having dozens of controls. So...
Besides, deliberatly set each control to fit Igor6 may make it abnormal in igor7 or on a normal-resolution display.
Still thank you:)
johnweeks
The only way to get Igor 6 to look right on a high-resolution display is to set the display's resolution to lower DPI. Of course, you lose the nice-looking high resolution graphics.
The best, of course, is to use Igor 7. But you say your procedures have problems. Are there compile errors? Or simply bugs? If you have not done it already, you should be sure that the top of your procedure windows has
#pragma rtglobals=3
to get the benefit of more stringent error checking.
JimProuty
-Matthew
I find this user-defined menu useful to change the size of controls in the the active panel:
Edit: the procedure code I put here doesn't solve the problem of the entire panel being too small, it just made controls inside the panel bigger, potentially causing text truncation inside of controls.
So I've removed the previously posted (and incomplete code) for now and will think about how to solve the problem another way (probably using PanelResolution on Igor 7).
wings
johnweeks wrote: The only way to get Igor 6 to look right on a high-resolution display is to set the display's resolution to lower DPI. Of course, you lose the nice-looking high resolution graphics.
#pragma rtglobals=3
We dont have compile errors.
The problem is that: our procedure runs slowly in igor7, while not the case in Igor6.
Especially the interface response becomes very slow when the number of control panel and other objects gets large. (our data is typically 300~700M and the procedure files is about 80 M)
There is no other difference except running speed.
Thanks
wings
-Matthew
#pragma IndependentModule=MyStuff
#pragma moduleName=MyModule
#pragma version=7	// circa Igor 7
Menu "Panel", dynamic, hideable
	FixedSizeMenu(), /Q, ToggleFixedSizePanel()
	Submenu "Appearance"
		AppearanceMenuItems(), /Q, SetWindowAppearance()
		"Set \"_IgorLarge\" fonts", /Q, SetControlFonts(JimsStuff#ActivePanel(), "_IgorLarge")
(I extracted this from a larger file, so I hope I didn't leave anything amiss.)
I'll do test, if it works, it would be great!!
wings
		"Set \"_IgorMedium\" fonts", /Q, SetControlFonts(JimsStuff#ActivePanel(), "_IgorMedium")
		"Set \"_IgorSmall\" fonts", /Q, SetControlFonts(JimsStuff#ActivePanel(), "_IgorSmall")
		"Set default fonts", /Q, SetControlFonts(JimsStuff#ActivePanel(), "")
		Submenu "Popup Menus"
			"Set \"_IgorLarge\" fonts", /Q, SetPopupFonts(JimsStuff#ActivePanel(), "_IgorLarge")
			"Set \"_IgorMedium\" fonts", /Q, SetPopupFonts(JimsStuff#ActivePanel(), "_IgorMedium")
			"Set \"_IgorSmall\" fonts", /Q, SetPopupFonts(JimsStuff#ActivePanel(), "_IgorSmall")
			"Set default fonts", /Q, SetPopupFonts(JimsStuff#ActivePanel(), "")
(I extracted this from a larger file, so I hope I didn't leave anything out.)
I dont find the key function "setcontrolfonts". can you show me that function?
thanks
JimProuty
thanks
My code didn't solve your problem, actually, so I've removed it. I think a PanelResolution option might work if it is in effect before the panel is first built.
JimProuty
Here's a potential solution (it's not perfect because it works by killing and recreating the window without correcting the window top left position).
Still, it may be helpful:
Requires Igor 7 or later.
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
#pragma ModuleName=PanelSizes
#if IgorVersion() >= 7
	Submenu "Size"
		"Make Panel Bigger",/Q, PanelSizes#MakeTopPanelBigger()
		"Make Panel Smaller",/Q, PanelSizes#MakeTopPanelSmaller()
		"Make Panel Normal Size",/Q, PanelSizes#MakeTopPanelNormal()
		"\\M1:(:Panel Resolution = "+num2str(PanelResolution(WinName(0,64)))
		"\\M1:(:Screen Resolution = "+num2str(ScreenResolution)
#endif
static Function MakeTopPanelBigger()
	String panel= WinName(0,64)
	if( strlen(panel) )
		Variable currentRes= PanelResolution(panel)
		Variable newRes= BiggerResolution(currentRes)
		String newCode= RewritePanelCodeResolution(panel, newRes)
		KillWindow/Z $panel
		Execute/Q/Z newCode
		DoIgorMenu "Control", "Retrieve Window"
static Function MakeTopPanelSmaller()
	if( strlen(panel) )
		Variable newRes= SmallerResolution(currentRes)
		KillWindow/Z $panel
		Execute/Q/Z newCode
static Function MakeTopPanelNormal()
	if( strlen(panel) )
		Variable newRes= 1 // This is the default setting in effect when Igor starts.
		KillWindow/Z $panel
		Execute/Q/Z newCode
static StrConstant ksResolutions= "72;96;120;144;192;240;288;384;480;"
static Function BiggerResolution(currentRes)
	Variable currentRes
	Variable nextRes= ActualResolution(currentRes)
	String strRes= num2istr(nextRes)
	Variable whichOne = WhichListItem(strRes, ksResolutions)
	Variable numItems= ItemsInList(ksResolutions)
	if( whichOne >= 0 && whichOne < numItems-1)
		nextRes = str2num(StringFromList(whichOne+1, ksResolutions))
		nextRes = str2num(StringFromList(numItems-1, ksResolutions))
	return nextRes
static Function SmallerResolution(currentRes)
	Variable currentRes
	if( whichOne > 0 )
		nextRes = str2num(StringFromList(whichOne-1, ksResolutions))
		nextRes = 72
	return nextRes
static Function ActualResolution(currentRes)
	Variable currentRes
	Variable actualRes= currentRes
	Variable screenRes= ScreenResolution // On Macintosh this was always 72 before Retina displays. On Windows it is usually 96 (small fonts) or 120 (large fonts).
	if( actualRes == 0 ) // points
		actualRes = screenRes
	elseif( actualRes == 1 )
		if( screenRes == 96 )
			actualRes = 72
	return actualRes
static Function/S RewritePanelCodeResolution(panel, newRes)
	String panel
	Variable newRes
	String code= WinRecreation(panel, 4)
	Wave/T tw = ListToTextWave(code, "\r")
	// insert three lines of code before line 2 (line 0 is Macro... and line 1 is PauseUpdate...)
	InsertPoints 2,3, tw
	tw[2]= "	SetIgorOption PanelResolution=?"
	tw[3]= "	Variable oldResolution = V_Flag"
	tw[4]= "	SetIgorOption PanelResolution="+num2istr(newRes)
	Variable lines= numpnts(tw)
	// insert SetIgorOption PanelResolution=oldResolution
	// before EndMacro (line lines-1)
	InsertPoints lines-1, 1, tw
	tw[lines-1]= "	SetIgorOption PanelResolution=oldResolution"
	// convert back to code
	String list
	wfprintf list, "%s\r", tw
	return list
PanelSizeMenus.ipf (3.65 KB)
