stdev for each column of 2d matrix
I have a series of waves all the same length which I have concatenated together to form a matrix with them all stacked on top of one another. I wish to know the average and standard deviation of each column of the matrix (so for the points wave1[0],wave2[0],wave3[0], then for wave1[1],wave2[1],wave3[1] etc).
What's the most efficient way of doing this?
Thanks
Igor
Use MatrixOP. For example, if your concatenated matrix is wave1 you can execute:
Variable rows=dimSize(wave1,0)
MatrixOP/O averages=sumCols(wave1)/rows
Similary,
MatrixOP/o variances=varCols(wave1)
I should also note that in IP7 you can simply compute WaveStats on a per column basis (use /PCST).
I hope this helps,
