Igor procedures as web application
I was wondering whether it is possible to convert Igor procedures (e.g. executing calculations) into a web application, which may be accessible to anyone from the web. with the possibility of modulating parameters and adapting the calculation accordingly.
Thanks for letting me know.
Mannaia
aclight
The simple answer to your question is yes, but there are some caveats and doing this can be a bit complicated. If you execute
DisplayHelpTopic "Igor as a WWW CGI-Bin Server"
at Igor's command line, the relevant section of the Advanced Topics.ihf file will be displayed. Note the last two paragraphs in that section, which refer you to two other places to look.
In case you aren't familiar with them, the Technical Notes are located within your Igor Pro folder. Look in the Technical Notes/Igor Pro Tech Notes folder and you'll find them. The example experiments can be opened from Igor's File->Example Experiments->Feature Demos->Web Page Demo menu item.
