Graph Live Updateupon user interaction
Dear Forum,
It's the first time I am trying to use sliders and other controls to streamline the interaction of user with the script.
In a first attempt to do that, I have a slider that scales from 0 to 100 that will define a threshold which will sit between the minimum and the maximum value of a wave containing data. The threshold will be used towards finding peaks, and to better aid the user to define a suitable threshold, it should be plotted as a line across the graph where the data (containing a succession of small and large peaks) is also plotted. Now, I could do an update button to update the graph every time the thumb position is changed - but that's a bit too lame. Instead, the threshold line should update automatically. Can anyone please give me a hand, maybe with some example code, or with suggestion of core functions to do this? I did have a look at some of the examples that come with Igor, but a more direct and specific example would be of extra value to begin understanding this.
Many thanks in advance.
R.
rhjpires
Hi John,
thanks for the reply.
I post below the relevant part of the code. DisplayDataProc is called from another panel not shown here. Once called it creates a graph containing a control bar area with a slider and an update button next to it. This update button is what i use to define the threshold. ideally, I would like to get rid of it altogeher. Can you maybe illustrate what exactly you mean based on this?
Many thanks,
R.
Function DisplayDataProc(CtrlName) : ButtonControl
	string CtrlName
	Wave WF
	Display /N=Graph_Data /w=(210, 0, 1150, 150) /k=1 WF // and display in a graph
	ModifyGraph /W=Graph_Data rgb(WF)=(0,0,0)
	ControlBar /L /W=Graph_Data 100
	Variable /G Percent_Max
	SetVariable setvar0,pos={0,120},size={90,50},limits={0,100,1},value=Percent_Max
	Slider Slider01, pos={0,10}, size={50,110}, ticks=10, live=1
	Slider Slider01, limits={0,100,1}, variable=Percent_Max, side=2, thumbColor=(1000,1000,0)
	Button Update_Threshold, pos={55,10}, size={40,80}, Proc=Update_Threshold, title="UPDATE"
	Make /O /N=2 W_Threshold_X
	Make /O /N=2 W_Threshold_Y
	AppendToGraph /W=Graph_Data W_Threshold_Y vs W_Threshold_X
	//For FFT
	Duplicate/O WF WF1
	If (mod(numpnts(WF1),2) != 0)	// check remainder of division of 2
			deletepoints numpnts(WF1)-1, 1, WF1	// delete last point if remainder is not zero
	FFT /OUT=3 /WINF=Hanning /DEST=WF_FFT WF1
	Display /N=Graph_FFT /w=(210, 210, 410, 410) /k=1 WF_FFT // and display in a graph
	SetAxis /W=Graph_FFT bottom 0.1,2
	SetAxis /W=Graph_FFT /A=2 left
Function Update_Threshold(CtrlName) : ButtonControl
	String CtrlName
	//Display threshold to be used in the peak detection routine
	Wave WF, W_Threshold_X, W_Threshold_Y
	Variable /G Threshold = ((Wavemax(WF)-Wavemin(WF))*Percent_Max/100)+Wavemin(WF)
	W_Threshold_X[0] = 0
	W_Threshold_X[1] = pnt2x(WF, numpnts(WF)-1)
	W_Threshold_Y[0] = Threshold
	W_Threshold_Y[1] = Threshold
	DoUpdate
END
johnweeks
I get it now :)
You need an action proc for the slider and SetVariable controls that does what the button's action proc does. If I were doing it, I would write a single function with appropriate inputs that changes the graph. Then call it from the two action procs.
rhjpires
Thank you John! That makes perfect sense.
So I change controls from the button to the slider, and I appended the PROC to the slider01, and replaced the function control from ButtonControl to SliderControl. The whole thing compiles, but at runtime I get a syntax error of "expected right parenthesis".
Can anyone tell me what exactly I am doing wrong?
Currently, it looks like this:
//Function to close window after baseline correction and display baseline corrected graph
Function CloseWindow(CtrlName):ButtonControl
	String CtrlName
	MenuSubtractBaseline()
	DoWindow /K Graph_Baseline
	SVAR RawWaveName
	String/G WaveNewName = RawWaveName+"_sub"
	Display /N=Graph_Data /w=(210, 0, 1150, 350) /k=1 $WaveNewName
	ModifyGraph /W=Graph_Data rgb($WaveNewName)=(0,0,0)
	SetAxis /W=Graph_Data Bottom 0,5
	Execute /P "WMAppendAxisSlider()"
	ModifyGraph mode($WaveNewName)=4,marker($WaveNewName)=19,rgb($WaveNewName)=(0,0,0)
	DoUpdate
	//SetVariable setvar0,pos={0,120},size={90,50},limits={0,100,1},value=Percent_Max
	Slider Slider01, pos={0,50}, size={50,200}, ticks=10, live=1// thumbColor=(1000,1000,0)
	Slider Slider01, Proc=Update_Threshold
	//Button Update_Threshold, pos={0,280}, size={80,80}, Proc=Update_Threshold, title="UPDATE"
	DoWindow /F Graph_Data
Function Update_Threshold(CtrlName) : SliderControl
	String CtrlName
	SVAR WaveNewName
	Variable /G Threshold = ((Wavemax($WaveNewName)-Wavemin($WaveNewName))*Percent_Max/100)+Wavemin($WaveNewName)
	W_Threshold_X[1] = pnt2x($WaveNewName, numpnts($WaveNewName)-1)
	DoUpdate
END
jtigor
I have two initial thoughts...
First, because this error occurs at runtime and not at compile, the problem may be related to the Execute statement.
Second, enable the debugger if you haven't tried this already. To enable it, right click on the procedure window and select the Enable Debugger item in the context menu. When the error occurs, Igor with open the debugger window with the execution point at the line after the position where the error occurred.
This may keep you afloat until real help arrives.
rhjpires
Thanks for the input JTIgor!
The execute command, and the rest of the code, works fine until I change the control from Button to Slider.
The execute command adds a top control bar with a horizontal slider to allow sliding over the x-axis wit a small data-window; it is very useful for long datasets or with many features packed very closely together. It is in fact part of the standard Igor packages.
I did try using the debugger, but it did not highlight any errors, or warning signs. The moment, I click the slider01 thumb it is havoc: the syntax error dialog pops up telling me that it was expecting a right parenthesis somewhere and I cannot continue.
So by activating the slider with a mouse click I get a problem. I had no problems before in clicking in the slider to set the value for the associated variable.
So, I continue confused.
jtigor
The debugger will not highlight (as I recall) faulty code, but it will pause execution at the line following the line where the error occurred.
A missing parenthesis should be caught during compile unless is occurs in a macro or if there is an error in the design of an Execute command. I would look at these two possibilities.
johnweeks
Each control type has its own required format for the action proc. A slider requires one with the signature like this:
Function MySliderProc(name, value, event) : SliderControl
	String name		// name of this slider control
	Variable value	// value of slider
	Variable event	// bit field: bit 0: value set; 1: mouse down,
						//   2: mouse up, 3: mouse moved
But these action procs with simple input parameters are old-fashioned. You really should be using the ones that take a structure as input:
Function ActionProcName(S_Struct) : SliderControl
	STRUCT WMSliderAction &S_Struct
The structure-based procs give better performance, and when we create new features for a control, it is likely to be supported only by the structure-based versions. That's because it's easier to extend the structure for new features without breaking existing code.
