smoothing and filter frequency
is there a way to relate the "num" parameter in binomial smoothing to the filter frequency of a corresponding Gauss-filter (or experimental Bessel-Filter)?
Essentialy I want to filter/smooth the data in processing and want to relate this to a possible experimental filtering.
Thanks in advance
Schmaud
May 24, 2017 at 02:46 am - Permalink
just an update: I did some test and for "smooth" the following seems to apply approximately:
Cuttoff frequency = sampling frequency / 5 / root(par)
( with cutoff frequency is the frequency where only 1/root(2)of the amplitude is left after filtering)
This is of course not very analytical, for the more theoretically inclined:
Some more information than in the online help is here:
https://www.wavemetrics.com/products/igorpro/dataanalysis/signalprocess…
The mentioned algorithm Marchand and Marmet (1983) is here:
http://aip.scitation.org/doi/pdf/10.1063/1.1137498
Best
schmaud
August 16, 2017 at 07:13 am - Permalink
August 16, 2017 at 09:23 am - Permalink
In the limit of large smoothing parameters (which is the Gaussian filter), your approximate numerical factor (1/5) is ideally sqrt(2 ln2)/(2*pi) = 0.1874
Also, for n>50, to achieve highest accuracy use
Variable/G root:V_doOrigBinomSmooth=1Even for low filter orders, a further improvement in finding the closest corresponding Gaussian filter (and its corresponding band-width) is to use (for unit sampling interval) a Gaussian variance sigma^2 = n/2 + 1/8 .
EDIT UPDATE: the exact result for the binomial filter cutoff frequency is actually buried in the above Marchand reference. After rewriting their equation (10) for unit-time sampling with my IP analysis, and taking its inverse,
Fcutoff = (1/pi) * acos( 0.5^(1/(4*n)). This is easily derivable from the starting kernel{1/4, 1/2, 1/4}but is not as transparent as using the Gaussian approximation.August 29, 2017 at 05:08 am - Permalink
August 17, 2017 at 03:41 am - Permalink
Filtering is quite somewhat more complicated than initially thought...
[quote=s.r.chinn]your approximate numerical factor (1/5) is ideally sqrt(2 ln2)/(2*pi) = 0.1874[/quote]
Thank you - I prefer a rational explanation over some fudge factor any day.
[quote=johnweeks]File->Example Experiments->
[/quote]
I had not used them in years - I completely forgot how useful they are.
Thanks a lot for the great resource!
August 17, 2017 at 06:58 am - Permalink
August 17, 2017 at 09:27 am - Permalink
