    Igor procedure syntax highlighting on GitHub
I saw in this post (http://www.igorexchange.com/node/6013) and several other posts on IgorExchange about the using GitHub for development.
I started to use GitHub but mostly I write code online (GitHub editor) when I am moving around and not having real data to test it.
In such case the syntax highlight does not work.
Do I need special directives or files for syntax highlighting to work.
Any suggestions from GitHub users.
Thank you.
[1]: https://github.com/github/linguist/blob/master/vendor/README.md
[2]: http://www.igorexchange.com/node/7572
June 11, 2017 at 09:04 am - Permalink
-Ankit
June 14, 2017 at 01:39 am - Permalink
