Giving desired name to Wave Average wave output - can I modify a read only procedure?
(I've accidentally posted this in the IgorExchange forum)
In short, I’ve noticed that in the Average Waves package I cannot use a decimal point for the output average wave name, for example: charge0.4_avg (bad).
My question was answered by HJ Drescher and Jim Prouty.
They suggested changing line 833, in the Average waves package to:
String AppCom = "AppendToGraph"+AFlags+" "+PossiblyQuoteName(AveWaveName)+XWaveInfo
However, the package procedure is a read only one.
Can I unlock it somehow to specifically change this line?
Cheers,
Yonatan
Locate the procedure file (start the package, use Windows->Procedure Windows->Waves Averages.ipf, click on the small sheet symbol on the lower left corner [left of the lock symbol], an information window pops up, click on 'Show file in Windows Explorer / Finder')
Open it in your favorite text editor and do the changes.
If you want to do the changes in Igor 6 you will have to start a new experiment, drag the file on the grey background area. In case the pen symbol is ruled out (where the lock symbol has been before) click on it to enable editing.
Igor 7 complains that the file is in use. I'd go for a third party editor in this case.
HJ
Copy the old file to the desktop and edit it there.
Right-click the file first to make sure it is not marked read-only.
Then copy it back.
Use an Admin account.
Another option might have been to append the function in the procedure window (to invoke in windows: ctrl+m) and define the
override
like so:
override Function WaveAverageDoItButtonProc(ctrlName) : ButtonControl
	String ctrlName
	SVAR/Z ListExpression=root:Packages:WM_WavesAverage:ListExpression
	if (!SVAR_Exists(ListExpression))
		DoAlert 0, "Some data required for the operation cannot be found. Try closing the panel and re-opening it."
		return -1
	SVAR/Z ErrorWaveName=root:Packages:WM_WavesAverage:ErrorWaveName
	if (!SVAR_Exists(ErrorWaveName))
		return -1
	SVAR/Z AveWaveName=root:Packages:WM_WavesAverage:AveWaveName
	if (!SVAR_Exists(AveWaveName))
		return -1
	SVAR/Z WA_ListOfWaves=root:Packages:WM_WavesAverage:WA_ListOfWaves
	if (!SVAR_Exists(WA_ListOfWaves))
		return -1
	NVAR/Z nSD=root:Packages:WM_WavesAverage:nSD
	if (!NVAR_Exists(nSD))
		return -1
	NVAR/Z ConfInterval=root:Packages:WM_WavesAverage:ConfInterval
	if (!NVAR_Exists(ConfInterval))
		return -1
	NVAR/Z ErrorMenuSelection=root:Packages:WM_WavesAverage:ErrorMenuSelection
	if (!NVAR_Exists(ErrorMenuSelection))
		return -1
	String theList="", theXList=""
	String aWave
	String TopGraph=WinName(0,1)
	String TopTable=WinName(0,2)
	Variable DoConf
	Variable Interval
	Variable AppndGrph=0, numXWaves=0
	ControlInfo WaveSourceMenu
	Variable ListSource=V_value
	if (ListSource == 1)		// by Name
		theList = WaveList(ListExpression, ";", "")
	if (ListSource == 2)		// from Top Graph
		if (strlen(TopGraph) == 0)
			DoAlert 0, "There are no graphs"
			return -1
//		theList = WaveListfromGraph(ListExpression, ";", TopGraph)
		numXWaves= XYWaveListfromGraph(ListExpression, TopGraph,theList,theXList)
//		if( numXWaves == 0 )
//			theXList=""
//		endif
		ControlInfo AverageAppendToGraphCheck
		AppndGrph = V_value
	if (ListSource == 3)		// from Top Table
		if (strlen(TopTable) == 0)
			DoAlert 0, "There are no tables"
			return -1
		theList = WA_TableWaveList("*", ";", TopTable)
	Variable ErrorType = 0
	ControlInfo GenErrorCheck
	if (V_value)
		ErrorType = ErrorMenuSelection
		if (ErrorType == 1)
			Interval = nSD
		if (ErrorType == 2)
			Interval = ConfInterval
	Variable numWaves= ItemsInList(theList)
	if (numWaves == 0)
		DoAlert 0, "You have no waves selected. If you have selected From Top Graph, make sure the Wave Name Template is correct."
		return -1
	// Version 6.23: changed to Yes, No DoAlert
	if (numWaves == 1)
		// DoAlert 0, "You have only one wave selected ("+theList+" if you have selected From Top Graph, make sure the Wave Name Template is correct."
		//return -2
		String warning= "Only one wave selected ("+StringFromList(0,theList)+")."
			warning += " Make sure the Wave Name Template ( \""+ListExpression+"\" ) is correct."
		warning += "\r\rContinue anyway?"
		DoAlert 1, warning
		if( V_flag != 1 ) 	// 1 == yes
			return -2
		ErrorType=0
	Variable/G root:Packages:WM_WavesAverage:numWaves = numWaves		// for the New Graph button proc
	ControlInfo print
	if (V_value)
		Print "Averaging "+num2istr(numWaves)+" waves: "+ReplaceString(";",RemoveEnding(theList,";"),", ")
	Variable wasPointByPoint= fWaveAverage(theList, theXList, ErrorType, Interval, AveWaveName, ErrorWaveName)
	Variable disableXWave= 1	// hide
	if( wasPointByPoint >= 0 )	// < 0 means fWaveAverage reported an error
		if (AppndGrph)
			DoWindow/F $(WinName(0,1))
			aWave =  StringFromList(0, theList, ";")
			CheckDisplayed $AveWaveName
			if (V_flag == 0)
				String TInfo = traceinfo("", NameOfWave($(aWave)),0)
				String AFlags=StringByKey("AXISFLAGS",TInfo)
				String XWaveInfo = PossiblyQuoteName(StringByKey("XWAVE", TInfo))
				if (wasPointByPoint && strlen(XWAveInfo) > 0)
					XWaveInfo = " vs "+StringByKey("XWAVEDF", TInfo)+XWaveInfo
					XWaveInfo= ""
				String AppCom = "AppendToGraph "+AFlags+" "+PossiblyQuoteName(AveWaveName)+XWaveInfo
				Execute AppCom
			if (ErrorType == 0)
				ErrorBars $AveWaveName, OFF
				ErrorBars $AveWaveName, Y wave=($ErrorWaveName, $ErrorWaveName)
		if( wasPointByPoint )
			disableXWave= 0	// enabled and showing
			disableXWave= 2	// disabled but showing
			// force calculated
			PopupMenu WavesAverageGraphXWave, win=WaveAveragePanel, mode=1
	ModifyControl WavesAverageGraphXWave, win=WaveAveragePanel, disable= disableXWave
	WA_ListOfWaves = theList
best,
_sk
