Wave dependency in user-defined functions
I try to use wave dependency in my function so that when Wave1 is changed, Wave2 will be updated automatically.
Function Dependency_test1()
	make /O/N=5 wave1
	wave1={1,2,3,4,5}
	make /O /N=5 wave2
	wave2:=wave1
but always get an error "Can't use local variables in dependency formula" during compile.
This seems to work in the command line. I am not sure what I am doing wrong?
Thank you!
This appears to work:
	make /O/N=5 wave1
	wave1={1,2,3,4,5}
	make /O /N=5 wave2
	SetFormula wave2,  "wave1"
When I use
Edit  root:wave1,root:wave2
I can change values in wave1 and those in wave2 change automagically.
Hope this helps,
Kurt
To be fully safe with liberal names and data folders, you need to do something like this:
// stupid example to make this point...
	String wname = "liberal name for my wave"
	make /O/N=5 $wname
	WAVE wave1 = $wname
	wave1={1,2,3,4,5}
// now create the dependency
	make /O /N=5 wave2
	String wave1name = GetWavesDataFolder(wave1, 2)
	SetFormula wave2, wave1name
If you now run this function, then go to Misc->Object Status you will see that wave2 depends on wave1 via this formula: "root:'liberal name for my wave'". Note the data folder path, and special quoting for the liberal name.
