String from ListBox Selection?
Is there already a way in ListBox to export a string of selected items? When ListBox is used as the Wave Selector Widget, one can use WS_SelectedObjectsList but I find no such equivalent for the general ListBox control.
johnweeks
You must write code that creates the list. You will have to write a loop that looks at the SelWave to find out if a given item is selected, then put the appropriate item into a list of selected items. Something like this (assuming a one-column list):
	Wave selWave	// may be available from the listbox event structure, if this is a ListBox action proc
	Variable npnts = numpnts(selWave)
	Variable i
	for (i = 0; i < npnts; i++)
		if (selWave[i] & 1)		// is it selected?
			... extract info on the selection from ListWave and do something with it...
