using vol2surf with X Y Z F(X,Y,Z) data set
I can put the data in some sort of 3D format using various interpolate functions. At the end, I would like to produce a surface which would look like it is wrapped around a set of point corresponding to a range of values of F(X,Y,Z). I watched the "Slicer" tutorial video and they talk about the "imageTransform vol2surf" function but I don't understand what format the data has to be to conform to this function. my data is similar to a series of MRI type slices but obviously not in the proper format. I keep getting the following error: "This image operation supports only unsigned char (/B/U)". All the data points F(X,Y,Z) are of values between 0 and 65535. I am sure the problem is in the way the data is set in the wave which causes the problem.
Thanks
Denis
As your data are not sampled on a regular rectangular grid your first step is interpolation. Considering your response from last week I'm guessing you might have some problem with the interpolation unless I misunderstood what you meant by the cylindrical pattern. It might be best if you communicated with me directly; feel free to send me an experiment with sample data so I can have a better idea of what you are dealing with.
February 8, 2010 at 01:31 pm - Permalink
I can't help you after that. Gizmo is above my pay grade.
Nick
February 8, 2010 at 06:58 pm - Permalink
