How to properly interpolate a Date/Time 1D wave?
I'm trying to solve this problem for quite some time now.
I have a 2Dwave that is a result of interpolation of the source matrix using this command:
ImageInterpolate/F={7,7} Bilinear, Matrix0Resulting matrix obviously does not fit the Date/Time Wave that was originally used for X axis values on the Image graph. The Wave itself is monotonically increasing but there are gaps in times in it.
I have tried to interpolate the Date/Time wave using:
resample/UP=7/N=41 Time_vThe resulting Wave matches the interpolated matrix in number of rows, it loses its monotonic nature though...After re-sampling it looks like on the attached file. It acquires strange oscillations on the edges of gaps.
How can I interpolate such a wave to match the
ImageInterpolate output and retain a monotonic nature?
Be sure that the date/time wave is double precision.
The Resample operation may be overkill for what you want. You might do something like:
This uses Igor's automatic interpolation on the right-hand side.
You might also consider abandoning the X wave and instead set the X scaling of your interpolated matrix to the required time values.
August 15, 2017 at 09:22 am - Permalink
There is a small problem with that code. It adds 7 extra points at the end of the interpolated wave. Is there a way to avoid it?
What do you mean by
August 16, 2017 at 01:14 am - Permalink
August 16, 2017 at 09:20 am - Permalink
This results in linear interpolation.
August 16, 2017 at 01:42 pm - Permalink
August 17, 2017 at 05:13 am - Permalink
August 17, 2017 at 09:29 am - Permalink
