Using weights in non-linear optimization
Hello all,
I am using Optimize function to minimize the value of a multi-variate function. This multi-variate function takes experimental data, and a simulated data is optimized for 4 parameters and this process works perfect.
function fit_parameters_nlo_IRF(w,p,q,r,T)
// params
//	w	: optional params (not used presently)
//	p	: coef for gas 1
//	q	: coef for gas 2
//	r	: coef for gas 3
//	T	: temperature of the system
wave w
variable p,q,r,T
//	print w[0],w[1],w[2],w[3]
variable E
variable n1, n2, n3
//------------ define experimental waves ---------------
wave expt_1	= root:intensity:ins_1
wave expt_2	= root:intensity:ins_2
wave expt_3	= root:intensity:ins_3
// compute spectra for A
spectra_1( T, 5 , 5 )
wave calc_1 = tDependent_spe_1_norm
n1 = dimsize(calc_1,0)
// compute spectra for B
spectra_2( T, 8 , 8 )
wave calc_2 = tDependent_spe_2_norm
n2 = dimsize(calc_2,0)
// compute spectra for C
spectra_3( T, 5 , 5 )
wave calc_3 = tDependent_spe_3_norm
n3 = dimsize(calc_3,0)
// compute error
make /o /d /n = (n_1) diff_1 = ( expt_1  -  ( p  * calc_1 ) )^2
make /o /d /n = (n_2) diff_2 = ( expt_2 - ( q * calc_2 ) )^2
make /o /d /n = (n_3) diff_3 = ( expt_3 - ( r * calc_3 ) )^2
E= wavesum( diff_1 ) + wavesum( diff_2 ) + wavesum( diff_3 )
//	report error
//	printf "Error : %5.9f\r",E
return (E) // E will be minimized by 'optimize'
Some of the experimental data points have high counts ( large y-values) while other have very small counts.
This means I should ideally use weighted non-linear optimization, giving higher weight to high y-value data points. But I could not figure out how to do that.
How can I implement this in the function (given above) which I am optimizing.
johnweeks
I think the only way to do that is to incorporate the weighting in the merit function you are optimizing.
It sounds like you are trying to do a fit to count data. Why not use FitFunc? FitFunc allows you to weight any way you want. Typically, for count data you would weight by sqrt(n).
