Panels & Co.
I am working on a panel where I'm using tabs. Is there a way to use the /FLT=1 in the NewPanel command. I would like to have the Tab panel and the floating option in the same time.
Thanks
Maybe I've misunderstood something- tabs are a type of control. You can put a tab control (or more than one!) into any control panel, including floating panels.
Floating panels behave a little bit strangely with regard to editing, so you might want to develop your panel as a non-floating panel, then convert to floating when the panel is stable.
Thank you for the reply. So, when I do :
NewPanel /K=1 /W=(500,500,940,800) as " Spec Import Control " ---> all compiles OK!
when I use:
NewPanel /K=1 /FLT=1 /W=(500,500,940,800) as " Spec Import Control " --> I get all the time an error, each time when I try to change in between tabs. The change is anyway done but the error is there. Error: "There are no graph or panels or the specified window does not exist ".
If you are saying it should work in the same way for floating or non-floating windows, I'll try more to get the error.
Best, T
By the way, that command doesn't explictly set a panel *name*, only a *title*.
Here's a quick demo of floating panels and tabs:
#pragma rtGlobals=1		// Use modern global access method.
Macro CreateTabbedFloatingPanel()
	DoWindow SpecImportPanel
	if( V_Flag )
		KillWindow SpecImportPanel
	Variable flt=1	// 0 for development
	Variable initialTabNum= 0
	NewPanel/N=SpecImportPanel/K=1 /FLT=(flt) /W=(500,500,940,800) as " Spec Import Control "
	TabControl tab0,pos={15,12},size={406,270},proc=SpecTabProc,tabLabel(0)="Tab 0"
	TabControl tab0,tabLabel(1)="Tab 1",value= initialTabNum
	Button button0inTab0,pos={101,71},size={115,21},proc=Tab0ButtonProc,title="This button is in Tab 0"
	Button button0inTab1,pos={102,71},size={115,21},proc=Tab1ButtonProc,title="This button is in Tab 1"
	CheckBox checkboxInTab0,pos={105,107},size={92,14},title="Checkbox in Tab 0"
	CheckBox checkboxInTab0,value= 0
	if( flt )
		SetActiveSubwindow _endfloat_
	SpecTabProc("",initialTabNum)
StrConstant ksControlsInTab0= "button0inTab0;checkboxInTab0;"
StrConstant ksControlsInTab1= "button0inTab1;"
Function SpecTabProc(ctrlName,tabNum) : TabControl
	String ctrlName
	Variable tabNum
	Variable disabled = (tabNum == 0) ? 0 : 1
	ModifyControlList ksControlsInTab0, win=SpecImportPanel, disable=disabled
	disabled = (tabNum == 1) ? 0 : 1
	ModifyControlList ksControlsInTab1, win=SpecImportPanel, disable=disabled
Function Tab0ButtonProc(ctrlName) : ButtonControl
	String ctrlName
	DoAlert 0, "This button is in Tab 0"
Function Tab1ButtonProc(ctrlName) : ButtonControl
	String ctrlName
	DoAlert 0, "This button is in Tab 1"
