Cubic and linear baseline
Hi all,
Just a question.....I have a single peak with some background and i tried 2 sets of fitting. First case, i used ''linear'' baseline and i did the fitting and the result was ok. I then tried to do it using ''cubic'' and it worked much better which i expected since the background does not look very linear. Just out f curiosity, i then tried to set to zero the K2 and K3 terms of the cubic function, essentially leaving myself with a linear function. I just wanted to see if the software will give me similar coefficients as in my initial try when i used ''linear'' baseline. However, the coefficients were very different but the goodness of fit (chi square) was identical to the one i obtained when i initially used the option of ''linear'' baseline. Any ideas for that? I hope my message is not very confusing. Thanks a lot
HJDrescher
This might arise from different initial guesses and too large epsilon values.
Hard to tell without displayed data and fits...
From the manual (Overview of Curve Fitting):
Unless you know a great deal about the fitting function and the data, it is unwise to assume that a solution is a good one. In almost all cases you will want to see a graph of the solution to compare the solution with the data. You may also want to look at a graph of the residuals, the differences between the fitted model and the data. Igor makes it easy to do both in most cases.
HJ
johnweeks
In order to avoid problems with a cubic polynomial overflowing on large X values, the cubic baseline fits to a normalized X range. So, yes, the fitted linear term should be quite different from the linear baseline. But the result should be pretty much identical.
