Sticks and markers graph: Sticks not present in .eps image
I use Version: 7.0.5.2 (Build 30037). When I draw a graph with mode=8, i.e. sticks and markers, and I save it as eps with
SavePICT/O/EF=1/E=-3/S as QuickPath() + name + ".eps"
, then the sticks to not appear in the .eps image. At the same time, they appear correctly in a .png file.
Sorry, I have ot attach pdf instead of eps, because eps is not an allowed extension for upload.
Is there any way to get my eps image correct?
Best regards, Joerg.
Problem-eps-converted-to.pdf (3.64 KB)
I can not reproduce this using this simple test:
make/n=5 jack=x;display jack
ModifyGraph mode=8,marker=19
SavePICT/O/E=-3/EF=1
I suggest sending a report to support@WaveMetrics.com including the system info and a copy of your experiment (you can save just the graph using File->Save Graph Copy.)
Use Help->Contact Support or copy the system info from the Help->About Igor Pro dialog's System info button.
Another option is to provide commands as I did above that will reproduce the problem.
Larry Hutchinson
WaveMetrics
Hi Larry,
many thanks. Your "cannot reproduce" message has helped me tracking down the error. If it works corretly on your side, the error must be somewhere in my code.
I found a function that has basically done
ModifyGraph lsize=0
With
 lsize=0, mode=8
the sticks appear erroneously on the screen and they correctly do not appear in the eps file.
Problem solved :-)
Best regards,
Joerg.
