<span>Hi,<br />
I' m trying to extract a name from a string that starts and ends with a <pre><code class="language-igor"><</code></pre> and <pre><code class="language-igor">></code></pre> which I'm trying to get rid of. I've been using <pre><code class="language-igor">sscanf </code></pre>and it works for the lesser than sign at the beginning but not the other sign at the end. <br />
<br />
function test()
string name
sscanf "<Signal001>", "%*[<]%s%*[>]", name
print name
</code></pre><br />
As a result I get: <pre><code class="language-igor">Signal001></code></pre><br />
<br />
Any suggestions ?</span>
Others already posted versions which work, so I'll just focus on why this does not work.
The reason is that the "%s" specifier also eats the ">". In your case you could get away with
function test()
string name
sscanf "<Signal001>", "<%[A-Za-z0-9]>", name
print name
but I personally lean towards the regexp as that is the most generic solution.
Sounds like you have a good solution using regular expressions, but the ReplaceString function is also very easy to use, assuming the "<" and ">" characters would never show up in the name.
November 15, 2017 at 04:43 am - Permalink
In , the "1" and "-2" are required to remove the first and last characters because string indexing is zero based in Igor.
November 15, 2017 at 06:17 am - Permalink
November 15, 2017 at 07:11 am - Permalink
November 15, 2017 at 11:29 am - Permalink
November 17, 2017 at 02:51 pm - Permalink
