How to make the axis labels automatically rotate with the box in Gizmo?
Hello friends,
Does anyone know how to make the axes' labels (like long, lati, and alti in X, Y, and Z axes) automatically rotate with the box a in Gizmo?
I tried to tune in the settings, not workably at last.
Cheers,
Peter
PS: I use Igor Pro 7.06 version in MacOS.
peterming wrote: Hello friends,
Cheers,
Peter
After many times of trying, I just added annotations with proper rotations beside the axes. It is a workaround.
Cheers,
Peter
Cheers,
Peter
This is unfortunate. If you are displaying axes just double-click your axes object in the info window. In the dialog click the Axis Labels tab, choose an axis from the list on the left and then set your axis label using the various controls on the right.
peterming wrote:
Cheers,
Peter
Thanks for your response. Well, it's difficult to make the labels follow the axes in an obedient way when I rotate the box.
Peter
