Shortcuts with contextual menus
I have added a custom user button to the Data Browser. This custom button creates a popup contextual menu. I have programmed the menu, and I have a function associated with a keyboard shortcut. I am not able to use the shortcut to fire the function.
Here is some minimalist code that demonstrates the issue I'm having.
static function IgorStartOrNewHook(igorApplicationNameStr)
  string igorApplicationNameStr
  Execute/Q "CreateBrowser"
  Execute/Q "ModifyBrowser appendUserButton={Button, \"myButton()\", 1}, echoCommands=0"
function myButton()
  PopupContextualMenu/N "Button"
Menu "Button", ContexualMenu
  "Do it/1", /Q, doIt()
function doIt()
  print "Do it!"
If I click the button, "Do it!" is correctly printed. If I try the shortcut, the function does not execute. If I remove
ContextualMenu
from the
Menu
option, then I get a new option in the toolbar, and my shortcut fires correctly.
Am I implementing this incorrectly? Or is this a bug?
JimProuty
Shortcuts work only if the menu is in the menubar. Shortcuts don't work for contextual menus.
jcor
Where in the manual can I learn about data browser buttons? I can't find it, and didn't figure out how to run the example code from kgord.
