Printing difference of two waves
I have little experience with Igor.
I have two waves a,b. I want to print their difference. In other scripting languages (Python, IDL) I can say: print a - b. In Igor I need
<br />
Make /N=(10) diff = a[p] - b[p]   // need to know the number of elements, Make diff = a[p] - b[p] is not good enough<br />
print diff<br />
Really?
UHe
_sk
I think this is more of a limitation in the implementation of the command window (ctrl+j) or the
print
operation.
In any computation (programming language) something has to store the result of an operation, even if it appears as temporary or "anonymous", like so (executed at the command line):
matrixop/o res = a - b; print/f res; killwaves res
That being said there is something inconsistent for me going on here and it may be related. Take for example the following code:
function/wave diff_wave(a,b)
	wave& a
	wave& b
	matrixop/o/free res = a - b
	return res
function test_print()
	make/o/n=3 a = p
	make/o/n=3 b = p+1
	wave c = diff_wave(a,b)
	print c
	//print diff_wave(a,b) //will not compile
Regardless if executed in a function or at the command prompt, the following will give an error:
(provided,
a
and
b
exist in the global scope when executing from the command prompt).
While the
test_print()
function prints the difference correctly:
'_free_'[0]= {-1,-1,-1}
Why can't
print
take directly the wave reference from
diff_wave()
but needs a specially defined reference as in
best,
_sk
uhe
... looks like it is so. Thanks for the hint about using matrixop.
UHe
JimProuty
_sk wrote:
Why can't
print
diff_wave()
_sk
The free wave expires outside of the function runtime context. That is, once it hits the command line, it has already been disposed.
thomas_braun
JimProuty wrote:
_sk wrote:
Why can't
print
diff_wave()
_sk
I'm not sure this really answers the question.
I'd say in general that print needs a wave reference and not a function returning a wave.
Function/wave GetWave()
	Make/O data = p
	return data
Function test_print()
	print GetWave() //will not compile
If you only index a single point from the wave
print GetWave()[0]
then it compiles and does what you expect.
_sk
I was under the impression that
function/wave
returns a wave reference and not a wave; in other words, there is no copy.
But what you point out is correct. If print gets a single value then it chugs through it.
Even if the
/free
in
matrixop
is removed (in other words,
res
is not cleared upon exiting the
diff_wave
scope) the code below still fails.
	wave& a
	wave& b
	return res
//execute from the command line or from a within function fails
While we are at it, why doesn't the following work?
make/o/n=3 c = diff_wave(a,b) //same number of rows as a and b
While this does work:
duplicate/o diff_wave(a,b), c1
best,
_sk
thomas_braun
function/wave
Sorry my wording was inaccurate. It should have been "print needs a wave reference and not a function returning a wave reference".
_sk
function/wave
A function returning a wave reference should be equivalent to a wave reference, otherwise composability breaks. I think the reason for the error is that
print
make
need the whole data and not a pointer to the whole data, while
duplicate
apparently doesn't.
These inconsistencies in operations and functions throughout Igor are a sign of evolution and cruft accumulation through the years but, overall, contribute in a negative manner to the use of the environment as a whole.
best,
_sk
Igor
Try IP8 beta (after the next build). It should allow you to execute e.g.,
MatrixOP/O/P=2 ff=a-b
This will print to the history the difference between tokens 'a' and 'b' but it will not leave behind a wave 'ff'. If you need to use ff for some later computation you can execute:
 MatrixOP/O/P=1 ff=a-b
More details (especially about /P=2) will be provided in subsequent documentation.
