Filled colour in contour plot
Hi Igor Wave metrics members
I want to make filled contour plot for my x,y,z data. I followed previous topic
"http://www.igorexchange.com/node/2366"
but I couldnt get filled contour. Maybe I missed about appending the image plot and my contour plot.
Here I attached my contour plot.
my data is in x,y,z format and have 20 rows each.
Please help me to solve this issue.
Thanks
proland
Add the following to the procedure window.
#include <appendimagetocontour>
Now, "Append Image or Fill Between Contours" will appear as the last item in the Graph menu list.
thabes
proland wrote: Add the following to the procedure window.
When I copy past this command I get syntax error. that means letters should be separated? plus which image I should append to the contour. I didnt plot anything to append.
JimProuty
Look in your Packages submenus.
Graph->Packages->Fill Between Contours...
thabes
I upgraded my igor. and I used package. Tank you very much.
But at the corner of the image is still white and is there a short cut to remove numbers from contour.
best regards
JimProuty
thabes wrote: I upgraded my igor. and I used package. Tank you very much.
The region outside of your contour's boundary is interpreted as being the smallest z value (no extrapolation is done).
thabes wrote: and is there a short cut to remove numbers from contour.
Remove labels by using the Graph->Modify Contour dialog, and set Labels to None.
igornoob2017
JimProuty wrote: Look in your Packages submenus.
The best answer!
