Dimension item label error while attempting to populate output variables wave
I am trying to follow "Wave Assignment and Indexing Using Labels" example in the help file, with a slight modification: I am using WaveStats to generate my output variables instead of FindPeak, intended to populate a wave with 10 rows and 4 columns After setting dimension labels for the desired WaveStats output variables, the next 4 lines of code, which would place the extrema values and their row locations into the appropriate cells of the output wave, generate the error "Couldn't find the given dimension item label." I'm sure I'm missing something, ignorant of an indexing rule or something, but I can't see it. Hopefully the code posts correctly, this is my first time sharing any code on the forum.
•Make test=sin(x/30)
•WaveStats test
  V_npnts= 128; V_numNaNs= 0; V_numINFs= 0; V_avg= 0.33891;
  V_Sum= 43.3805; V_sdev= 0.582272; V_sem= 0.0514661;
  V_rms= 0.671753; V_adev= 0.492791; V_skew= -0.643665;
  V_kurt= -0.851805; V_minloc= 127; V_maxloc= 47;
  V_min= -0.887431; V_max= 0.999991; V_minRowLoc= 127;
  V_maxRowLoc= 47; V_startRow= 0; V_endRow= 127;
•Make/N=(10,4) metrics
•SetDimLabel 1,0,Vmin,metrics
•SetDimLabel 1,1,Vmax,metrics
•SetDimLabel 1,2,VminLoc,metrics
•SetDimLabel 1,3,VmaxLoc,metrics
zephyr070
The command that failed is:
metrics[%Vmin]=V_min
As I suspected, it was a syntax error on my part. Your amended code contains a [0], and I guess I need to brush up more on that section of the help file. What does the [0] designate? I noticed the label assignment example doesn't include that character (code reposted below). Thank you very much for the help!
// Make a wave and get peak parameters
Make test=sin(x/30)
FindPeak/Q test
// Create a wave with appropriate row labels
Make/N=6 PeakResult
SetDimLabel 0,0,'Peak Found', PeakResult
SetDimLabel 0,1,PeakLoc, PeakResult
SetDimLabel 0,2,PeakVal, PeakResult
SetDimLabel 0,3,LeadingEdgePos, PeakResult
SetDimLabel 0,4,TrailingEdgePos, PeakResult
SetDimLabel 0,5,'Peak Width', PeakResult
// Fill PeakResult wave with FindPeak output variables
PeakResult[%'Peak Found']   =V_flag
PeakResult[%PeakLoc]        =V_PeakLoc
PeakResult[%PeakVal]        =V_PeakVal
PeakResult[%LeadingEdgePos] =V_LeadingEdgeLoc
PeakResult[%TrailingEdgePos]=V_TrailingEdgeLoc
PeakResult[%'Peak Width']   =V_PeakWidth
// Display the PeakResult values and labels in a table
Edit PeakResult.ld
hrodstein
The example uses a 1D wave so one index is needed to specify the row.
Your case uses a 2D wave so two indices are needed, one for the row and one for the column.
"[0]" in John's example means "row 0".
zephyr070
Rookie mistake! Thanks again to both of you for the help. I am trying to come up with a routine to loop through a very large set of sinusoidal data, which indexes the minima and puts those x value locations into a table to give something like "Cycle# StartRow StopRow." Then I will use those values as range inputs for plotting and further analysis on my 4 synchronized data waves. I'm sure I will be back on the forum soon.
-Kevin
