Axis Manipulation in Gizmo
I'm trying to make a 3D Scatter Plot with Gizmo. I'm having trouble adjusting the axes the way I need them. Is there a way to reverse axes in Gizmo? When I try to manually flip the axes I get the error message 'Bad Outerbox Limits'.
Basically my figure is of several spectra (intensity vs wavenumber) and I'm trying to plot these against a third independent axis (an experimental variable).
I need to flip either the wavenumber axis or the third independent axis. But it won't let me do either, I'm guessing because I'm trying to set the "minimum" to my highest wavenumber value (which works fine for 2D plots).
Your help is greatly appreciated!
June 11, 2018 at 10:03 am - Permalink
June 11, 2018 at 10:32 am - Permalink
June 15, 2018 at 05:25 am - Permalink
June 15, 2018 at 05:26 am - Permalink
