Creating image or surface plot with proper waves and matrix
Hi all,
I am trying to create a image or surface plot, but my x wave (date_s), y wave (Dp), and z matrix (DDlogDp) are problematic. I would want replace rows of z matrix with x wave and columns of z matrix with y wave. Otherwise, I want to use a x wave, a y wave and multiple z waves (the multiple z waves are separates of a z matrix) for the plots. Please find my igor table.
Any comment would be very helpful. Thank you.
I am having trouble understanding what you want, but you can make an image plot using x and y waves, see below. For further analysis it might be useful to convert your DDlogDp wave to waveform format (uniformly spaced data points).
Keep in mind that when you plot an image using x and y waves. The x and y waves refer to the edges of the pixels, not the centers, and therefore need to have one additional data point.
July 20, 2018 at 12:46 am - Permalink
Your x wave "date_s" loaded as text instead of date numbers (seconds since Jan 1, 1904). I see that they are in 30 minute increments, starting at hour 0. You don't need this wave: setting the 2D matrix's X scaling to start at 05/01/2016 00:00 can be done with:
The Y "dp" wave, on the other hand isn't a linear series: it is exponential (taking the log results in a linear dp)
As oleytken pointed out, to use an auxiliary wave to provide image coordinates you need to provide coordinates of the edges, not the centers.
For that, I wrote this little routine to compute N+1 coordinates given an N point exponential y wave:
(not completely sure about the math there) and then ran it using:
I created an image plot using X scaling and a Y auxiliary wave, and used log (Z) colors to enhance contrast.
See the attachments for the result and for the experiment I used to create it.
July 20, 2018 at 11:54 am - Permalink
olelytken, Jim, thanks for your help! I am almost there, excepting treating irregular datetime on the graph. Please find 'NewDataset" folder in the attachment. Now I have "dat" at 30-min interval with breaks, "DnDlogDp", and "dpPlus1" in the NewDataset folder. Could you provide a way to creat image plot with this dataset?
August 16, 2018 at 09:44 pm - Permalink
You need to decide what representation you want for the gaps in the dates.
You could linearly interpolate the data values for intermediate dates.
You could generate an X date wave with an extra point, but you'd need to choose its duration.
Using an X date wave you'd end up with some stripes of wide pixels.
August 17, 2018 at 10:45 am - Permalink
In reply to you need to decide what… by JimProuty
I should make a clear. I'd make linear X date with empty pixels automatically, instead of interpolation. Thank you, guys. I will manage it since now.
August 19, 2018 at 07:23 pm - Permalink
