ipf in User Procedure folder not loaded when Igor loads
I consider myself a knowledgeable user so this is annoying me. I put a "test.ipf" file in the User Procedures folder in the Documents\WaveMetrics\Igor Pro 8 User Files path and expected it to load when Igor loads. However this is not happening. It worked when I put a shortcut to this folder in the Program Files\Wavemetrics\Igor Pro 8 Folder\Igor Procedures folder or the actual file itself. The way I'm checking if "test.ipf" gets loaded is if it shows up in the Procedure Windows menu.
I thought perhaps the folder was set wrong in the miscellaneous settings and reset it but that didn't fix it.
What am I doing wrong? I'm using Windows 10
If I put a shortcut of an extension in the Documents\WaveMetrics\Igor Pro 8 User Files\Igor Extensions (64-bit) to an extension in the Igor Pro 8 folder then it loads. For instance, putting shortcut to the VDT2 extension in Documents\WaveMetrics\Igor Pro 8 User Files\Igor Extensions (64-bit) loads the VDT2.
ipf files in the Documents\WaveMetrics\Igor Pro 8 User Files\Igor Procedures are loaded but those in the Documents\WaveMetrics\Igor Pro 8 User Files\User Procedures are not.
September 4, 2018 at 01:23 pm - Permalink
Igor does not automatically load procedure files in "User Procedures". It loads them if you use a #include statement.
For details, execute:
DisplayHelpTopic "User Procedures Folder"September 4, 2018 at 02:27 pm - Permalink
Ahh ok. I misinterpreted that. Thanks.
September 5, 2018 at 07:17 am - Permalink
