Analysis packages don't work
Hi all,
Today I encountered the following problem - I loaded wave and would like to do fitting using curve fitting, but an error appears:
"Procedures need to be compiled. You won't be able to use user-defined fit functions."
Then I tried to open packages in Analysis tab, but they don't work, Function Compilation Error appears with the following text:
"expected ';' or <cr>
Error in WMBatchCurveFitResults:plotResultsInsideGraph
TextBox /W=$(graph) /C/N=FitStatsText/F=0/A=LT errorMatrix[index]"
Please find attached mentioned errors.
How can I solve this problem?
I just removed Igor Pro 8 and reinstalled it, but the same errors occur.
April 20, 2019 at 05:42 am - Permalink
I also tried to open File --> Example Experiments --> Curve Fitting --> Batch Curve Fitting Demo, and the Function Compilation Error arises. And the same error when trying to open Windows --> Packages --> Window Browser.
April 20, 2019 at 05:57 am - Permalink
It is a bug in WMBatchCurveFitResults.ipf that has lain undetected for quite a while.
Please replace your copy with the one attached (you may need admin privileges).
You will find the offending file in Igor Pro 8 Folder\WaveMetrics Procedures\Analysis\Batch Curve Fitting
April 20, 2019 at 09:10 am - Permalink
In reply to It is a bug in… by JimProuty
Physicist92Thank you very much! Now it works!
April 20, 2019 at 09:14 am - Permalink
