Show found fit parameters in plots in batch curve fitting
Hi all,
Please tell me, is there possibility to show found fit parameters in plots when using batch curve fitting package? I mean option like in Analysis --> Curve Fitting --> Output options --> Add textbox to graph.
Not as far as I can see. The closest thing to that is the Export button that gives you the option of "Export as Graph". The generated graphs contain a fit equation with the fitted coefficients.
April 22, 2019 at 09:47 am - Permalink
In reply to Not as far as I can see. The… by johnweeks
[quote=johnweeks]
[/quote]
Thank you! It would be great, if in future there will be opportunity to add textbox with found fitting parameters and their errors to graphs in batch curve fitting package.
April 22, 2019 at 10:01 am - Permalink
