Performance for circular correlation coefficient
Hi all,
I'm trying to calculate the correlation coefficient between two waves containing angles. From what I gathered, StatsCircularCorrelationTest() provides the functionality I want. However, I run into issues when the waves become very long (Igor locking up, beach ball etc). I want to do the calculation for waves containing >10k points.
Here is a minimal example:
Function test()
	Make/O/N=1000 one, two //barely works for 1000, locks up for large numbers, e.g. 10000
	setscale/I x, 0, 1, one, two
	one = gnoise(1)
	two = gnoise(1)
	StatsCircularCorrelationTest/PAA/Q one, two
	Wave W_StatsCircularCorrelationTest
	print W_StatsCircularCorrelationTest[0]
This is on Igor 8.04B01 (Mac).
Is there a better way to only get the correlation coefficient?
Igor
/PAA is a particularly difficult calculation because it involves looping over the data and recomputing some stats after removing one pair of points.  Can you describe the motivation for choosing this option?
serrano
I see. The motivation for choosing /PAA was just because it is the first example that came up in the circular correlation demo. To be honest, I haven't looked much into the actual theory at all. All I'm interested in at the moment is something like Pearson's r but for angles, e.g. dihedral angles of an MD trajectory with ~10k time points.
