Fitfunc report only for fit convergence
I am using Fitfunc command to fit 1000 data sets with a user defined fit function. I want to know which fit was NOT converged properly.
However, general report in command line contains too many information.
Can I simply get the wave name of non-converged fits? I have tried to use V_flag but it does not report properly.
ChrLie
Here is something that I use in a user function that reports an error if a fit fails. Maybe that helps.
function/WAVE PeakFitRatios(Mask, enA, widthA, enB, widthB)
	Wave Mask
	variable enA, widthA, enB, widthB
	wave/Z cube
	wave/Z M_Groups
	if(!WaveExists(cube) || !WaveExists(M_Groups))
		return $""
	variable timer = StartMStimer
	variable rows = DimSize(M_Groups, 0)
	variable cols = DimSize(M_Groups, 1)
	Make/D/O/N=(rows, cols) M_Ratio = NaN
	//SET CURVE FIT OPTIONS
	variable/G V_FitOptions = 4
	variable/G V_FitError = 0
	variable ErrorCount = 0
	// set the energy/channel ranges over which the gaussian peaks are fitted
	variable lowA = enA - widthA
	variable highA = enA + widthA
	variable lowB = enB - widthB
	variable highB = enB + widthB
	variable i,j, PeakA, PeakB
	for (i=0; i<cols; i+=1)
		for (j=0; j<rows; j+=1)
			if (mask[j][i])				// fit pixel if M_Mask is 1
					// Extract spectrum from cube and scale energy
					MatrixOP/O spec = beam(cube, j, i)
					wave spec
					SetScale/P x 0, 0.01, spec
					try
						// fit first peak
						K0 = 0; K2 = enA
						CurveFit/Q/H="1010"/NTHR=0 gauss spec(lowA,highA) /D; AbortOnRTE
						wave peak = $"fit_Spec"
						PeakA = area(peak)
						// fit second peak
						K0 = 0; K2 = enB
						CurveFit/Q/H="1010"/NTHR=0 gauss spec(lowB,highB) /D;  AbortOnRTE
						PeakB = area(peak)
						M_Ratio[j][i] = PeakA/PeakB
					catch
						if (V_AbortCode == -4)
							ErrorCount +=1
							variable CFerror = GetRTError(1)
							printf "Curve fit error at coordinate %g, %g: %s\r", j, i, GetErrMessage(CFError)
							M_Ratio[j][i] =NaN
					endtry
	// clean up
	KillWaves/Z W_coef, W_sigma, Spec, fit_Spec
	printf "%g pixels not fitted due to CurveFit errors.\r", errorcount
	Printf "Time: %g seconds \r", stopMStimer(timer)/1e6
	return M_Ratio
In reply to by maru
johnweeks
maru wrote:
Thanks for the advice. I found V_FitNumIters and can get the iteration number to check if the fit is converged.
I'm not sure this is a good way to do it. I would use a combination of V_fitError and V_fitQuitReason:
Variable V_FitError = 0
Variable V_FitQuitReason = 0
FuncFit ...
if (V_FitError)
	... handle error such as singular matrix ...
if (V_FitQuitReason == 1)		// max iterations without convergence
	... do something about it ...
Note that you need to create these variables yourself. Also, you should zero them right before calling CurveFit or FuncFit.
