Complex waves error
Greetings forum,
I have a form (Cos6A+iSin6A) each Cos6A and Sin6A.
Below is a part of my code which is inside a for loop:
Variable/C ci = sqrt(-1)
string Angs= "Angs"+num2str(b)
            Duplicate/o root:tryFolders:tests:$(EachPointFolder):$Angles , root:tryFolders:tests:$(EachPointFolder):$Angs
            wave Angles_each = root:tryFolders:tests:$(EachPointFolder):$Angs
            Angles_each = atan(DifferenceY[p]/DifferenceX[p])*180/Pi
            string Angs6= "6_Angs"+num2str(b)
            Duplicate/o root:tryFolders:tests:$(EachPointFolder):$Angles , root:tryFolders:tests:$(EachPointFolder):$Angs6
            wave Angles_each6 = root:tryFolders:tests:$(EachPointFolder):$Angs6
            Angles_each6 = 6*Angles_each
            string cosAng= "CosAngs"+num2str(b)
            Duplicate/o root:tryFolders:tests:$(EachPointFolder):$Angles , root:tryFolders:tests:$(EachPointFolder):$cosAng
            wave Cos_Angles = root:tryFolders:tests:$(EachPointFolder):$cosAng
            Cos_Angles = cos(Angles_each6)*180/Pi
            string sinAng= "SinAngs"+num2str(b)
            Duplicate /o root:tryFolders:tests:$(EachPointFolder):$Angles , root:tryFolders:tests:$(EachPointFolder):$sinAng
            wave Sin_Angles = root:tryFolders:tests:$(EachPointFolder):$sinAng
            Sin_Angles = ci*sin(Angles_each6)*180/Pi
            string iSin= "iSin"+num2str(b)
            Duplicate/o root:tryFolders:tests:$(EachPointFolder):$Angles , root:tryFolders:tests:$(EachPointFolder):$iSin
            wave i_sin = root:tryFolders:tests:$(EachPointFolder):$iSin
            //i_sin = (ci)*Sin_Angles
            string Complexi= "Cmplx"+num2str(b)
            make /c/n=(numpnts($iSin)) root:tryFolders:tests:$(EachPointFolder):$Complexi
            wave Complex_wave=root:tryFolders:tests:$(EachPointFolder):$Complexi
            Complex_wave= cmplx(Cos_Angles,Sin_Angles)
 I get the following error: Function is not available for this number type:
Attached image shows how the waves looks without cmplx(Cos_Angles,Sin_Angles)
Thanks a lot
error cmplx
For starters, your wave declaration should be:
Wave/C Complex_wave=...
