Iteratively creating & naming numerical variables
Hello, I am trying to make a for loop in which I reference a different wave and create a new variable (with a corresponding name) in each iteration, each with specific names. [I think] I was able to do the wave part by iteratively making the string:
string waveref = "waveN2_" + num2str(i+1)
and then calling that specific wave (waveN2_1, waveN2_2, etc.) with $waveref, but I can't figure out how to iteratively make new numerical variables, with corresponding names (E_1, E_2, etc.). I'd then like to assign values to those newly-created&named variables within the loop.
Thank you!
johnweeks
You can't create a local variable or string with a run-time name. You *can* make global variables, though, in much the same way as a wave:
Function MakeVariables()
	String varname
	Variable i
	for (i = 0; i < 10; i++)
		varname = "MyGlobalVar"+num2str(i)
		Variable/G $varname
		NVAR v = $varname
		v = i
ChrLie
As alternative I'd consider using a labelled wave:
Function MakeLabelledVarWave()
    String varname
    Variable i
    Make/D/N=10 W_Var
      varname = "MyVar"+num2str(i)
      SetDimlabel 0, i, $varname, W_Var
      W_var[%$varname] = i + enoise(0.1)
    edit W_Var.ld
Then you don't clutter up your experiments with global variables and you can make it /FREE if only needed locally.
