Quick and dirt tool for swapping Y axes.
I all too frequently add a trace to a graph with two different Y-axes and add it to the wrong one.    Below is a procedure that adds a menu to the right-click popup to swap the axes.  After right-clicking a trace, click the bottom menu item.  The initial stuff is "borrowed" from the manual.  Put it in your local user procedures folder.
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
Menu "TracePopup", dynamic
    TraceClickerPosition(), /Q, TraceClicker()
function /s TraceClickerPosition()
    getmouse /W=kwTopWin
    variable /G V_TraceMenuX=V_left
    return "Swap left and right Y axis"
function TraceClicker()
    // figure out graph and trace names
    GetLastUserMenuInfo
    // figure out mouse position within graph on SECOND click
    getmouse /W=$S_graphName
    string s_info=traceinfo(S_graphName, S_traceName, 0)
    string s_xwave=stringbykey("XWAVE",s_info)
    string s_yaxis=stringbykey("YAXIS",s_info)
    RemoveFromGraph $S_tracename
    if (CmpStr(s_yaxis, "left")==0)
    	// delete this curve and re-add it on the right
    	AppendToGraph/R $s_tracename vs $s_xwave
    	// delete this curve and re-add it on the left
    	AppendToGraph/L $s_tracename vs $s_xwave
    return 1
aclight
FWIW, Igor 8 and later already have this feature built-in--right click on a trace and select "Move to Opposite Axis".
