Bin-centered X values on Histograms
I am trying to make a histogram of some data I have:
12.5
16.4
16.6
18.0
18.6
22.3
23.4
23.7
28.1
I have chosen 5 bins with width 4 and bin start 10. When I plot this histogram, everything seems fine. I have attached an image of this (Graph 21).
However, I apply the bin-centred X values for the purpose of fitting a graph through the centre of the bin and, the bars on the histogram appear to show incorrect data. I have attached an image of the wrong data (Graph 16). I believe the issue is because the bars now begin at the bin centre, because if I represent the data with a marker and line instead of bars, the data appears correct.
Is there any way I can fix this such that the graph is fitted through the centre of the bins but keeping the histogram displayed correct with bar mode?
Histogram without bin-centered X values and its fitting with Gauss. Center of the Gauss is on 19.085. Histogram with bin-centered X values and its fitting with Gauss. Center of the Gauss is on 21.085.
ilavsky
I dealt with this in one place and I eventually created different x-wave for each set of data - but in this case I have xwave and ywave pairs. If you are using x-scaling, you can shift the bar graph using Offset option in GUI, so it is centered by shifting it by half of the bin width. This applies command  ModifyGraph offset={-2,0} in your case. If you do this only for the bar graph, it will look as expected and is easy to do through GUI.
johnweeks
You have analyzed the source of the problem correctly. It is a difficult problem that has no terrific solution. The various things you can do are discussed in our help: DisplayHelpTopic "Curve Fitting to a Histogram".
