Surfer 7 Grid file format
I need to load (image) data files that are saved in the Surfer 7 Grid format. The file is binary and contains different sections (e.g. header, grid info and data). The format is well documented,
http://grapherhelp.goldensoftware.com/subsys/surfer_7_grid_file_format…
and I managed to put a simple loader together:
Function GRDLoader(filepath)
	string filepath
	Variable refNum
	Open/R/F="GRID Files (*.grd):.grd;" refNum as filepath
	if (refNum == 0)
		return -1
	// extract file name from path as wave name
	String wName = ParseFilePath(3, S_FileName, ":", 0, 0)
	// pre-define byte positions of grid info section and data
	variable GridInfoStartByte = 20
	variable DataStartByte = 100
	// load GRID info section, first two enties are "long",
	// rows and columns of grid/image
	Make/I/O/N=2/FREE W_RowsCols
	FSetPos refNum, GridInfoStartByte
	FBinRead/B=3 refNum, W_RowsCols
	// load rest of the grid info section as double
	Make/D/O/N=8/FREE W_Scaling
	FSetPos refnum, GridInfoStartByte+8
	FBinRead/B=3 refNum, W_Scaling
	// load DATA section
	Make/O/N=(W_rowsCols[0] * W_rowsCols[1])/D $wName /Wave = M_Data
	FSetPos refNum, DataStartByte
	FBinRead/B=3 refNum, M_Data
	// redimension to matrix (note that cols and rows are swapped for propper display)
	Redimension/N=(W_rowsCols[1],W_rowsCols[0]) M_Data
	// ... more code to set wave scaling
	Close refNum
However, at the moment the start byte positions of the different section are hardcoded and were identified using the binary file reader (https://www.wavemetrics.com/code-snippet/rudimentary-binary-file-reader). This works for all files I have encountered so far but a more versatile solution is preferred. The sections seem to be tagged by hex values, but I was unable to identify those in the binary files (an example file is attached).
Any hint to what I'm missing is highly appreciated!
Best
Christian
WDS1_Si_TAP_Quant.grd_.zip (794.65 KB)
KurtB
This is not the cleanest code, but may give you a start (sorry - I have not had a chance to check it with your file yet):
	string filepath
	Variable vRefNum
	Open/R/F="GRID Files (*.grd):.grd;" vRefNum as filepath
	if (vRefNum == 0)
		return -1
	// check for minimum length
	FStatus vRefNum
	variable vFileLength=V_logEOF
   	if(vFileLength<12)
		print "Error: not a GRD file."
		Close vRefNum
		return -1
	// Intel/Windows little endian
	variable vByteOrder=3
	string sID
	variable vLength
	variable vError = 0
	do
		// read tag: ID then length
   		sID = "    " // 4 characters
		FBinRead vRefNum, sID // 4-character ID
   		FBinRead/U/B=(vByteOrder)/F=3 vRefNum, vLength // 32-bit word - length
   		strswitch (sID)
   			case "DSRB": // 0x42525344  - Header
   				variable vVersion
   				FBinRead/U/B=(vByteOrder)/F=3 vRefNum, vVersion
   				Print "GRD File Version Number: " + num2str(vVersion)
   				break
   			case "GRID": // 0x44495247 - GRID
				FBinRead/B=3 vRefNum, W_RowsCols
				FBinRead/B=3 vRefNum, W_Scaling
   				break
   			case "DATA": // 0x41544144 - Data
				FBinRead/B=3 vRefNum, M_Data
   				break
   			case "FLTI": // 0x49544c46 - Fault Information
   				// .. code to read fault info section
   				break
   			default:
   				print "Error: Unknown tag."
   				vError = -1
   				break
   		endSwitch
   		if (vError != 0)
   			break
   		// ... code to check end of file
   		FStatus vRefNum
   		if (V_filePos >= V_logEOF)
   			break
	while(1)
	Close vRefNum
	return vError
Hope this helps,
Kurt
ChrLie
Hi Kurt,
thanks a lot! Much appreciated!
The obvious never occurred to me that hex is converted to characters (or vice versa), even though I could spot it in the binary reader snippet, however, it seems that I looked at the hex values in the wrong byte order. I also understand now better how FBinRead works!
Thanks again!
C
KurtB
You are very welcome.
I took inspiration from a TIFF reader that I posted previously here.
Cheers,
Kurt
