johnweeks Please tell us more. What exactly do you want to delete? Rows? Columns? Multiple? One? To delete column 5 from a matrix: DeletePoints/M=1 5, 1, matrixwave To delete row 5: DeletePoints/M=0 5, 1, matrixwave Since the zero dimension (rows) is default, the second one doesn't need the /M=0 flag, but it doesn't hurt. Replace "matrixwave" with the actual name of your matrix. Log in or register to post comments May 8, 2020 at 11:16 am - Permalink
vpratap397 I want to delete just one point or may be just a few. Don't want to delete whole row or a column. thanks Log in or register to post comments May 8, 2020 at 11:19 am - Permalink
johnweeks You can't do that to a matrix. If you delete one point from a row, what happens to the last column? Or do you want to replace that element with something like Nan? Log in or register to post comments May 8, 2020 at 11:27 am - Permalink
vpratap397 I see your point. Then I guess I have to convert the 2D wave to 1D waves and then delete points separately in each wave. Log in or register to post comments May 8, 2020 at 11:32 am - Permalink
johnweeks Yes, that would be what you have to do. And then it is permanently a 1D wave. Log in or register to post comments May 8, 2020 at 05:00 pm - Permalink
aclight If you're using Igor 7 or later, you can use the SplitWave operation to easily split a multidimensional wave into multiple lower dimensional waves (in your case, 2D->1D). Log in or register to post comments May 11, 2020 at 05:09 am - Permalink
aclight And I see now that you asked a different question about SplitWave, so I guess you already know about it :) Log in or register to post comments May 11, 2020 at 05:11 am - Permalink
In reply to And I see now that you asked… by aclight vpratap397 Yes, I did. Thank you. Log in or register to post comments May 11, 2020 at 07:06 am - Permalink
To delete row 5:
thanks
