    How to remove repeated numbers from a wave
Hello forum,
I have a wave "all_pts", it contains float numbers. I want to remove repeated values. Example is shown in image. I want to have a wave similar to "all_pts_noRepeated" , as you see in this wave, values 10.2569 and 9.5245 are removed because they are repeated.
what is the easiest way to do so?
Thank you,
Try out FindDuplicates present since IP7.
May 17, 2020 at 03:31 am - Permalink
Histogram might also be an option
May 17, 2020 at 04:13 am - Permalink
In reply to Try out FindDuplicates… by thomas_braun
Thanks for the comment,
I forgot to mention that my igor version is 6.1.
May 17, 2020 at 02:19 pm - Permalink
You could also Sort the wave and Extract the points that differ from the previous points
May 18, 2020 at 12:44 am - Permalink
In reply to You could also Sort the wave… by olelytken
As I recall, when dealing with floating point values you should incorporate a tolerance in your matching. That is, consider values to be the same if within "+/- alpha" of the value.
May 18, 2020 at 06:02 am - Permalink
I might add that Igor 6.1 qualifies as ancient software :)
May 18, 2020 at 09:53 am - Permalink
