Code hint cut off in procedure window
In a procedure window a code hint appears in the status bar, but is cut off for multiline hints  There seems to be no way to scroll through the text.  Is there a way to display the entire hint?
IGORVERS:8.04
BUILD:34722
OS:Windows 10 Enterprise
OSVERSION:6.3.18362
IGORFILEVERSION:8.0.4.2
Hint text for "do" is highlighted in image below.
johnweeks
Well, no, that space wasn't ever intended for multi-line text. It was originally for "status" messages. However, you can right-click on a term of interest like "do" and get a contextual menu that includes "Insert Template for xxx" and "Help for xxx".
aclight
I don't think there's much value in seeing the additional lines for the terms that result in multiple lines of text. These tend to be the flow control keywords which are pretty straightforward.
