Color table in Gizmo/Image plot
Dear all
I created 10 x 10 image map and 3D representation using Gizmo, as an attached file.
The Z-value is assigned to blue(minus) to red(plus) using the "RedWhiteBlue256" color table with "Reverse Colors" option, considering the physical meaning.
In the Gizmo / Image representation, however, the "Reverse Colors" option nor the "Color Table Wave" option" does not appear. So, the color image in the Gizmo is reversed.  Is there any way to use the same color arrangement?
Also, the image plot in the gizmo is gradated and looks good. In the "Modify Image Appearance" menu, however, I could not find the "gradation (?)" option. Is there any way to get the similar image?
Thank you.
Kaz
image.pdf (351.55 KB)
azumi
Dear all
I could solve the problem by attaching the second line to the script.
ModifyGizmo ModifyObject=image1,objectType=image,property={ cTab,RedWhiteBlue256}
ModifyGizmo ModifyObject=image1,objectType=image,property={ invertCTab,1}
Thank you .
Kaz
Igor
Hello Kaz,
I'm glad you were able to find the solution on your own.  FWIW I added an Invert CTab checkbox to the dialog in IP9.
AG
