Fill Between Contours in X + Y + Z 2D matrix contour plot
Dear Forum,
I am a rather inexperienced Igor Pro 7 user. I have generated a contour plot by combining a matrix of Z values (2D wave) and two 1D waves of X and Y values. The plot generated is attached. I now would like to fill in between the contour lines to have a "continuous" plot. I tried doing this by using the Graph Package "Fill Between Contours". The contour selected is the 2D Z wave and I choose "Continuous" as the fill option. The result is attached. It seems that the Fill Image generated is shifted to (0,0) with respect to my original data. I suspect this has to do with using the Z matrix, without reference to the actual X and Y values. I have the same issue when I generate a 3D surface from the contour plot: everything is shifted to 0,0.
How can I fix this to generate a proper plot (contour and 3D)? Is there a better way to generate the contour plot?
Thank you for your help, suggestions and comments.
We could help you better if you attach your actual Igor experiment.
August 12, 2020 at 10:14 am - Permalink
