how to calculate interquartile range of numeric wave
Hi all,
I am wondering, if there is a function in igor to calculate interquartile range of a numeric waves. The alternative is to calculate the first and third quartile. However, I still need a command to calculate these 2 quartiles.
My code in progress is as the following:
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
Function medianGaussian(JVmatrice)
wave JVmatrice // 2D wave
Variable sum=0
Variable i=0 // We use i as the loop variable.
Make/O/N=(dimSize(JVmatrice,1)), JV
Make/O/N = (dimSize(JVmatrice,0)), tempwave
Make/N=800/O tempHist;DelayUpdate
do
tempwave = JVmatrice[p][i]
JV[i]=median(tempwave)
Histogram/C/B={-7,0.1,800} tempwave,tempHist;DelayUpdate
CurveFit gauss tempHist /D
print(JV[i])
//calculate inter quartile range
//print(W_coef[1])
//print(W_coef[2])
//print(W_coef[3])
//print(W_coef[4])
i += 1
while(i < dimSize(JVmatrice,1))
return JV[i-1]
Use StatsQuantiles. IQR is stored in the variable V_IQR and in the wave W_StatsQuantiles
September 2, 2020 at 04:52 am - Permalink
Thanks for the suggestion sjr51. It works.
September 4, 2020 at 07:33 am - Permalink
