Make auto graph margins label and tick aware
Currently the graph margins set to 'auto' do not care if a label and if/where the axis ticks are placed. I often create graphs where I switch the left axis ticks off and may not even show a label in some cases. I have attached a test graph with the label switched off and the tick location set to 'inside' (for dramatic effect I have also set the major tick length to 20). With the auto margins this creates a fairly big empty region, and I need to set the margins manually to get a neat result. It would be great if the auto margins would change according to the state of the Labels (off / empty = no added space or on / not empty) and tick Location settings (off / inside = no added space or outside).
test graph.pdf (7.88 KB)
Sure, here it is (I don't have the experiment file with the exact graph anymore, but this gives basically the same result):
Window Graph0() : Graph
	PauseUpdate; Silent 1
	Display /W=(560,60,840,280)  test
	ModifyGraph tick(left)=2
	ModifyGraph mirror=2
	ModifyGraph minor=1
	ModifyGraph noLabel(left)=2
	ModifyGraph standoff=0
	ModifyGraph btLen(left)=20
EndMacro
