Returning a wave from function
I have edited the following code:
Function PP()
Make /O /N=100 toto
toto=X*2
duplicate /O  toto tata
tata= gen_w(toto)
edit tata
Function gen_w(name)
wave name
duplicate /O name H
H=name/100
return H
When I execute PP(), tata is filled with expected values. It works well.
From the Command Window, if I execute:
print gen_w(toto)
only the first value of the wave (0) is printed. I was expecting an editing of the full wave.
Why am I wrong?
Thanks for your help.
Erik
chozo
In modern Igor environments your example does not even compile. The reason is that the return statement of a normal function is giving back a single (scalar double-precision) number. If you want to return a wave (reference) you need the /WAVE flag. Try this:
Function PP()
	Make /O /N=100 toto=X*2
	Wave workwave = gen_w(toto)
	tata=workwave
	edit tata
Function/WAVE gen_w(name)
	wave name
	duplicate /O name H
	H=name/100
	return H
Print will still give you just a single point, though (which you can choose now however). For example, to print the 10th point of the returned wave use:
print gen_w(toto)[10]
Erik_Kran
And another mysterious thing:
executing:
Function PP()
Make /O /N=100 toto
toto=X*2
duplicate /O  toto tata, titi
tata= gen_w(toto)
//titi=gen_w(toto)*2
wave name
duplicate /O name H
H=name/100
return H
modifies as well the existing titi file, but the command line in the code is now a comment, and this file should not change.
I guess there is an issue in my understanding of wave manipulation.
Erik
In reply to by chozo
Erik_Kran
Thank you. It works. There is however still the strange issue if the function is called twice. I mean, if the following code is executed:
Function PP_corr()
    duplicate /O  toto tata,titi
    tata=workwave
//    Wave workwave1=gen_w(toto)
//   titi=workwave1*2
    wave name
    duplicate /O name H
    H=name/100
    return H
The titi file is modified by the program, but the corresponding lines that should update tit have been cancelled.
What is wrong?
Thanks.
johnweeks
Wave references (and other types of references) can be confusing when you first encounter them. I might suggest some reading:
