Erratic behavior with complex arithmetic, e.g., sin(z) returns NaN
My code is producing unexpected results when taking the sine of a complex number.  I wrote the following test function to research the problem.
​Function testsine()
variable /c  a
a=cmplx(0,1)
print "a= ", a
print "sin(a)= ", sin(a)
print "sin(sqrt(-1))= ", sin(sqrt(-1))
[Click and drag to move]
The results printed in the Command Window are pasted here:
•testsine()
  a=   (0,1)
  sin(a)=   0
  sin(sqrt(-1))=   NaN
The built-in sine function is not handling complex numbers as the manual leads me to believe, i.e., sin(x+iy)=sin(x)cosh(y)+ i cos(x)sinh(y). Shouldn't this have produced the result (0, 1.1752) in both cases above, i.e., the sin(a) and sin(sqrt(-1))?
This is rather a 'problem' of the print command not expecting a complex number unless explicitly getting handed one. Try this:
Function testsine()
	variable/c a,b,c
	a=cmplx(0,1)
	b=sin(a)
	c=sin(sqrt(-1))
	print "a= ", a
	print "sin(a)= ", b
	print "sin(sqrt(-1))= ", c
Will give:
•testsine()
  a=   (0,1)
  sin(a)=   (0,1.1752)
  sin(sqrt(-1))=   (0,1.1752)
print/C also solves the problem easily
Function testsine()
variable /c  a
a=cmplx(0,1)
print/C "a= ", a
print/C "sin(a)= ", sin(a)
with result
•testsine()
  a=   (0,1)
  sin(a)=   (0,1.1752)
